I'm running Houdini on an M2 Max Mac Studio. When I leave a Karma render running in the background and switch back to working on the scene, the interface can feel noticeably less responsive.
Is there a way to keep Houdini more responsive while a render is running? I'm curious how some manage their workflow when rendering and working on another scene at the same time.
Houdini gets less responsive while a Karma render is running
241 1 0-
- scrub_td
- lewis_T
- 276 posts
You don't tend to work like this, as rendering is a computationally heavy process, so render engines are geared very much to
eat all your resources.
If you need to render frames to disk while still doing other work, it's best to export your scene to disk, and run it as a separate render process. When you do that you can specify the number of threads being used, and keep some for regular working.
L
L
