Node like heightfield output,map baker, export nothing.
I found that the files I created myself cannot be output even when opened by my colleagues' machines. But the file created by my colleague, when I open it here, I can output pictures.
I created the smallest case, which contains only one heightfield and one heightfield output. No one can output this file when they open it. Please help me take a look. Thank you very much.
can't export any png file
1028 1 0-
- xjtubigmi
- 1 posts
- オフライン
- JX Pearl
- 4 posts
- オフライン
Encountered the same issue.
Here is the cause I found after a while of debugging:
The frame range is set to a range that doesn't contain the current frame, NO MATTER whether the checkbox is toggled on or not. If you revert the range to the default range which is an expression that contains the entire timeline(and double check that it contains the current frame), then it should work. This seems to originate from the behavior of the ROP output node inside the HDA.
For the sample hip file uploaded, I tested with it and confirm that if you drag the frame to any number inside the playbar range, it will export. The current frame is 1 which is out of the range.
Edited by JX Pearl - 2026年8月28日 00:54:08
