Hello World,
I have two flapping birds (animated Bgeo)
They are flapping in the same direction with same tempo.
How can I altinate the flapping direction of the two girds without going back to the original hip file.
Steve
How can I change Animated Obj Direction
3281 6 2- aplink
- 365 posts
- stevenong
- 1631 posts
- aplink
- 365 posts
- aplink
- 365 posts
- bollili
- 205 posts
- aplink
- 365 posts
Yes, I am talking about the simple rotation.
I have two idendical Bird (Animated Bgeo Obj) flapping or rotating their wing with same tempo speed and same direction.
I am using TimeShift SOP to adjust the frequence of the flapping.
How can I altinate the flapping of the wing one from the other bird.
Thank you in advance.
Steve
Steve
- bollili
- 205 posts
Ah ok. So if I understand you correctly, you want to deform parts of the wings.
Probably, one of the first SOPs I would have a look at is the magnetSOP.
You could feed in some metaballs into input 2 that define the area that you can manipulate (rotate, transform…) with the sop's parameters.
http://www.sidefx.com/docs/houdini11.1/nodes/sop/magnet [sidefx.com]
and also http://www.sidefx.com/docs/houdini11.1/nodes/sop/bulge [sidefx.com]
Another solution could be the twistSOP: http://www.sidefx.com/docs/houdini11.1/nodes/sop/twist [sidefx.com]
Or even a combination of them.
Have a look at the examples, they are very helpful!
