I want to achieve this :
-Apply an image map on a grid and delete points of the grid whose color are less than 230 230 230
So basically what I do is :
-Create a grid
-Create a VEX geometry operator : global(P) -> vector to float -> (u v)colormap ->(Cd)Output
- Apply the vex geo operator in SOP
- Partition using color rule
- Blast
Now my problems/questions are :
- In Vex geometry operator , there are no “Uv space change” so my color map doesn't apply correctly, the UV seems wrong. Any ideas for that ?
- My partition operator has created a group for each different color, is there a way to group together point that have Cd > 230 230 230 ?
Thanks in advance !
Julien
VEX geometry operator UV / Partition question
3289 2 0- Undertaker
- 113 posts
- stevenong
- 1631 posts
Hey Julien,
You're connecting the position (P) of the geometry into the UV of the Colormap VOP which works correctly only if the grid is positioned with its lower left corner at the origin (0,0,0) & it is 1 unit by 1 unit.
It is better to assign UV to the geometry then read the UV in the VOPnet:
Parameter VOP -> Vector to Float -> U,V of Colormap VOP
To group the points/primitives, I used a Group SOP with Number (Enable), Operation set to “Group by Expression” & typed in the following:
$CR<230/255 && $CG<230/255 && $CB<230/255
You can download the hip file here [users.adelphia.net].
Cheers!
steven
Cheers!
steven
- Undertaker
- 113 posts
