merge object using level set
   15321   12   2
hi everyone:
this is from the spiderman3. using level set to merge object smoothly. I tried several times in houdini.But it not works.
could some nice people give a example to show how can I acheive this effect just using simple geometries?
two
three
four
five
six
seven
So,let me make it more clear.
Is it possible to quaue query the per vexel sdf attribute , do some math, and modify the attribute.
syzmatrix
This can be done with the Volume Vop SOP. Try converting both objects to SDFs using the IsoOffset SOP then piping them into a Merge and the Merge into Volume VOP SOP. An important thingto note though, is that on Spiderman the SDFs they used had positive values inside the surface and negative values outside, while Houdini's SDFs are reversed.
hi danBode
thanks very much for your reply. This is really nice of you to provide such a valuable suggestion.
I am working on it. There is still some problem I can not fix.
could you give a very simple hip file that I may understand it better.?
thank you very much again.
Here's a test I made for myself a while ago while trying to do the same thing. For smoothing the intersecting areas, I tried using the math from Spiderman, in a volume mix SOP but when I couldn't seem to get that working, I did my own math in a volume VOP SOP. Hope it helps.
Dan
dmb_sdfTest3.hipnc (542.1 KB)
Hi danBode
Thanks very much for your great contribution, you are really a nice person with excellent understanding of houdini. It is my pleasure to meet you here!
cheers 8)
sun
But how to control erosion of the level sets?Thanks.
