[help] weird point normal in H12
   4735   8   3
I was following Mathew's tutorial (http://vimeo.com/35656029) [vimeo.com]
the normal of the points on a circle doesn't seem to be right ….
pls kindly advise!
untitled.hipnc (56.9 KB)
Not quite sure what you want to do, but here's a fix for your scene, I didn't watch the tutorial you mentioned so … well …
cheers!
Manu
Fixed_Normals.hipnc (65.7 KB)
http://vimeo.com/user2522760 [vimeo.com]
http://stormbornvfx.com/ [stormbornvfx.com]
Manuel Tausch
Hi oat,
Looks like a display bug with the new viewport in H12.
I've noticed it as well. If you revert to H11 viewport in the preferences it works as expected.
I submitted a bug about that with support > The display of normals is still busted. I refer to the details view always
Rob
Gone fishing
Guess that's why i'm getting weird velocity vectors from impactAnalysis node.
wbr, Mudvin
I am talking about the display on the normal on points
Gone fishing
After all the stability fixes, this is the current bit of work that's being done. Once completed in a few days, points and curves should be able to display normals, velocity and other custom attributes.
circusmonkey
I'm talking about the same: turning on “v” in display options either crashing H12 or shows all the impact velocities pointing in the same weird direction.
wbr, Mudvin
Yeah I was getting the same thing, drove me nuts until I turned the h11 driver back on
