A geo with different pieces should be animated with particles…
I used the centroid expression to get one partcle for each piece. Afterwards they get some motion. Now I try to use the piece number and the particle number to copying the particle motion back on its related piece. Any help to achive this relationship would be a great help.
Enclosed a test file!
thanks!
Copying Particle motion to geo
3340 9 2- mickyblue
- 217 posts
- zarti
- 330 posts
- mickyblue
- 217 posts
- mickyblue
- 217 posts
- zarti
- 330 posts
mickyblue
what exactly do the both delet sops? I don't get it Zarti.
just making me sure that nothing else exists inside of each iteration , but the needed ‘ actors ’ .
so , let say , on 3rd iteration only the 3rd particle , 3rd center of group point and only the 3rd chunk group are processed and merged with previous iterations .
anyway , depending on your case ( heaviness ) , there might be other smarter ways worthy to investigate ..
.glad i could help and cheers
- mickyblue
- 217 posts
- tjeeds
- 339 posts
- mickyblue
- 217 posts
- mickyblue
- 217 posts
- tjeeds
- 339 posts
It actually works very well for unlike objects too, you just make sure you have a point for every object and use each objects class value to look up the corresponding point number. So if you have 200 pieces of unique debris you would create 200 points, move them and then move each piece to the point. It does depend on you objects being at the origin though, so be mindful of that. Also orientation is another issue, the Copy sop handles these things for you but to do it yourself you must build a rotation matrix from velocity or something. While the Copy sop is easier to use, stamping is slow when dealing with lots of geometry, this approach is much quicker but might initially feel more complex.
Jesse Erickson
Fx Animator
WDAS
Fx Animator
WDAS
