Hi
I got some particles moving along a path using a CREEP POP.
Used a TRAIL SOP to compute the velocity of the particles and appended
a POINT SOP to instance geometry onto the particles.
For some reason, can't get the instanced geometry to orient to the particles direction of motion.
In the POINT SOP I tried both: ADD VELOCITY ($VX, $VY and $VZ) and
ADD NORMAL ($VX, $VY and $VZ). Dunno what I'm doing wrong :?
Any ideas?
Orienting Instances to Particles Moving Along a Path
4759 3 2- furball
- 43 posts
- RudiNieuwenhuis
- 190 posts
- rweston
- 30 posts
Peter Quint has a Leaves Instancing tutorial that begins with a detailed discussion about orienting instances which may prove useful to you
http://vimeo.com/17309337 [vimeo.com]
- zarti
- 330 posts
furball
Hi
Any ideas?
maybe you are missing the UP vector or something similar which does what UP usually does .
.cheers
