This question is meant for someone who has actually completed this tutorial. Upon trying to finish the melting effect, I ran into an issue where the legoman's viscocity isn't being set correctly. I have followed all the steps in the tutorial, and have come to the same result multiple times.
We are using a beam to transfer viscocity to the point in our legoman, however we start with a viscocity of 0, so our legoman melts to the ground, when he should remain stationary.
Theoretically, the legoman should start at a high viscocity, with the beam removing viscocity at the contact point. It seems like the tutor has reversed this process, starting with no viscocity and having the beam add it. This process seems backwards to me.
If anyone could provide any information, I would be deeply appreciative.. Thanks for reading.
-Joseph
Houdini Embers and Ash Problem
5749 4 1- Midasssilver
- 310 posts
- Sadjad Rabiee
- 1391 posts
- Midasssilver
- 310 posts
- premini
Hi, i also followed that tutorial and things worked for me, remeber that you need to create an attribute called viscosity in the object source and tell the solver to use it, cant remember how exactly now but is explained well in the tut.
Additionally i think the initial value for that attribute is 1000000. not 0.
premini
- Netvudu
- 304 posts
