Hello. I have a problem transferring the tracked data from 3DEqualizer4 into Houdini. 3DEqualizer can export the tracked data into a fbx file but the problem is when i then import it into Houdini, the image begins to bounce around not matching the animation. “The footage lenght is from 0 - 557” But in houdini will the timeline change to 1-577 so the animation of the camera is longer than the footage file.
I know it is a bit confusing but try to import the fbx file. I can't find a solution, so any help would be gladly appreciated.
I can't send the footage in image format, so tell me if i should upload the original.
Footage: Fps 29.97 :?
3DEqualizer To Houdini - Problem - Solved
3607 2 1- starostka
- 5 posts
- tanantish
- starostka
- 5 posts
It was pretty damn dumb. I just exported the tracking data with fbx. into Houdini and then changed the timeline to match the footage sequence, and then i set the framerate. The problem was Houdini imports the data so the timeline gets longer then the footage sequence.
Thanks for your help anyway.
Benjamin Starostka Jakobsen
