Add message/Warning/Error to a OP via HDK
   3280   3   0
I figure addWarning and addError are protect methods of OP_Node. They can only be called during cookMySOP(), am I right?
is there a way I can add warning to other OPs instead itself?
something like:
OP_ROP* myRop = OPgetDirector()->findROPNode(“/out/myMantra/”);
myRop->addError(ROP_MESSAGE, “some message”);
You can only call those during a cooking code path. Or you can try using appendError() when outside a cooking code path. I'm not sure those will show up though unless you also made a call to opChanged(OP_UI_CHANGED).
Thank you, Edward.
So what I am trying to do is, I have a procedural shader hdk, when the procedural code hits an error, I wanna bring the error message to a ROP or a SOP. Is there a way to do so?
and one more question,
ROP_Node* rop = OPgetDirector()->findROPNode(“/out/my_Mantra/”);
rop->appendError(“OP_CHANGED”, ROP_MESSAGE,“whatMessage”,UT_ERROR_MESSAGE);
the document says that the appendError() needs first argument “const char* type”, I don't quite understand what it needs here. :?:
