Expressions, best practice
3027 5 3- Rudra
- 4 posts
Hey guys. I have left Houdini funs for a couple of years and back to them just a few days ago. Have found tons of new functionality and just a one question now is about expressions. Are you going to deprecate hscript expressions and leave them just for a backward compatibility? Is there any reason to use only python in expressions instead of hscript?
Edited by - July 7, 2013 15:02:49
- pbowmar
- 7025 posts
- Rudra
- 4 posts
- jparker
- 293 posts
For expressions that need to work quickly for multiple prims/points/vertices there are also the new *Wrangle SOPs, which are meant to replace some of the functionality of the Point/Primitive SOPs. There are new “point”, “prim” and “detail” VEX functions that can be used like the hscript equivalent.
From what I understand hscript would be very hard to multithread so it's speed will become more limited as time goes on and performance increases come by way of more CPU cores rather than speeding up single CPU speeds.
- Rudra
- 4 posts
- hanton
- 36 posts
In the tutorial “VEX Wrangle Workshop” http://www.sidefx.com/index.php?option=com_content&task=view&id=2512&Itemid=132, [sidefx.com] Ari Danesh said because of Houdini is built on VEX, using HScript will be faster if only want to play inside Houdini.
However, Python is a “Pipeline” language and has many powerful modules, so use it if want to communicate with other software or need to program seriously.
Also, the new Point Wrangle SOP is 10x faster than the Point SOP!
