1) i have a popaxisforce node
float speed = orbitspeed * fit(random(@id*4684687), 0, 1, 0.5, 4);
orbitspeed = speed;
suctionspeed = speed / 2.0;
@test = chramp(“../popaxisforce1/frequency”, 3, 0);
I want to read in the value of a parameter within vex (which works for wrangle sop) but here i am getting an error.
Any suggestion?
Vex DopNetwork + chramp
3162 2 0- schiho
- 101 posts
- 8582 posts
I think the problem is not reading the ramp but writing to @temp
many POP DOPs don't have enabled exporting of custom attributes so they simply error out if you do that
you can use POP Wrangle DOP to do that, or modify the POP DOP
in your case would be adding temp or * to popaxisforce1/geometryvop1/if_use_localspeed/snippet1/Bindings To Export parameter
I don't recommend unlocking the assets, maybe an RFE can be made to allow specifying this directly on POP DOP nodes as it's handy to export attributes from them
- 8582 posts
according to
H13 Particles Masterclass
http://www.sidefx.com/index.php?option=com_content&task=view&id=2631&Itemid=132 [sidefx.com]
you can just do
export float @temp = 0;
@temp = chramp(…etc
you can just do
@temp = chramp(…etc
