for some reason when i use the “use deforming” with an animation at SOP level the smoke doesn't interact anymore with my object.
in the file there are too different method, one using the SOP level animated object(which doesn't work) and another one using OBJ level animation (which works fine)
just go in the smoke DOP and use switch to see the different result
thanks for answering
issue with deforming static rbd and smoke interaction
2754 2 0- sami.tawil
- 172 posts
- eetu
- 606 posts
- sami.tawil
- 172 posts
