Displace Geometry By Image?
23559 13 2-
- Enivob
- 2659 posts
Hi All,
Is there any way to displace the geometry/mesh of an object by an image? I have some displacement maps that I have used in other 3D packages and I want to try them out in Houdini.
I have an image that shows my attempt using a Material to displace the surface on render but as you can see the mesh splits because it is a render time based solution.
I have a box that is flowing into a subdivide node. Now I want to take the result of that subdivide and connect it to the displace-by-map node. But being a new user I do not know what the name of that node would be called.
Can image map geometry displacement be done in Houdini?
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
- pelos
- 624 posts
- eetu
- 607 posts
Quite an old thread, but should have good info still: http://forums.odforce.net/topic/6517-unofficial-displacement-rendering-challenge/ [forums.odforce.net]
I recommend adding the re-dice displacement property:
http://www.sidefx.com/docs/houdini13.0/render/understanding [sidefx.com]
http://www.sidefx.com/docs/houdini13.0/props/mantra#vm_redice [sidefx.com]
- circusmonkey
- 2624 posts
Tearing hard edges is solved by
•Create a new user N
•Copy that N to the geometry
•Add vertex cusp N , set to Cusp N
•In your shader create a parameter > using you new user N > transform that N from object to camera.
•So we are cusping with N and we are using a new user N for our shading.
That is an old thread …
Rob
Rob
Gone fishing
- Enivob
- 2659 posts
Thanks for the replies. I am getting back to solving this problem and I want to try out circus monkey solution.
Sorry for being an ultra noob but I don't understand any of the steps.
I have my cube selected and I type the N-Key while mouse is over the Network area? I see the labels change…
Is a new user simply a copy of the node? or is it like an instance of the node?
- circusmonkey
- 2624 posts
- Enivob
- 2659 posts
@circusmonkey: Thanks for the file, I am still not sure where the surface of the far left cube gets the displacement information from. It looks like noise but I can't seem to find the noise generator.
I think I really want to try to solve this via modeling, not materials. At the end of there day I want a real mesh with real faces displaced by an image map. I guess it would be like a height field. Can Houdini do that?
Here is my simple example node setup. If I could get an image map to drive the group #s and the strength for those groups it might work how I imagine.
Hmmm…this looks promising but it is only for a grid, not a box or other geometry.
http://www.sidefx.com/exchange/display.php?author=adam_glazier [sidefx.com]
- circusmonkey
- 2624 posts
You will need to create a vopsop / pipe in an image > and via its luminance displace along normal.
Gone fishing
- Enivob
- 2659 posts
I have added a vopsop to the end of my UV textured sphere object.
When I insert a texture inside the vosop, followed by a displace, I do get geometry displacement. However, there does not appear to be a mechanism for relaying the UV coordinates to the texture node inside the vopsop.
How is that handled?
Do I need to use more than one input on the vopsop?
NOTE: I am using two images, one a baked displace map and the other a companion version of the same map with AO baked into the texture. So I want one map to be used for the rendered diffuse surface and the other map for displacing the surface geometry.
As you can see in the image the displace version of the map has no link to the UVs so it can not synchronize with the AO version of the map.
- old_school
- 2540 posts
A couple things.
To import uv's in to the VOP SOP network, they have to be of type point and you need to use a Bind VOP to reference the attribute by name and type.
It is common to use the luminance value of the RGB texture map for displacements.
See example file for changes.
- circusmonkey
- 2624 posts
- Enivob
- 2659 posts
Thanks circus monkey,
The grid works as expected and looks nice with matching displace and AO textures.
Jeff,
Your file works well too. Although I do get some warning message that I don't understand when I try to save it locally from within Houdini Apprentice.
Jeff,
- old_school
- 2540 posts
That warning is most likely caused by an asset that was wrapped up in to my scene file by accident. It can be safely ignored.
I turn on the preference that allows Houdini to save a copy of assets to the current scene file for portability reasons only. I like to share scene files and I have no idea in what environment they will be used in so I enable this option. This is a user preference and defaults to off as it can lead to scene bloat when you have a lot of custom assets in use in your Houdini scene.
If you enable this option in the main Houdini preferences, the warning should go away.
- Yamatoto
- 9 posts
