Is there anyway to force updating of the `run(“chopls ../geometry1”)` expression in the Channel Name of a Noise Chop when the number of channels brought in by my geometry Chop changes?
At the moment I have to bypass/un-bypass the node for it to recook. Perhaps there is a better way to match the channel names/count?
`run` expression in chops not updating
2439 4 2- JordanWalsh
- 143 posts
- Sadjad Rabiee
- 1391 posts
- JordanWalsh
- 143 posts
Thanks, Thats what I have in a callback now at the moment.
I was just wanted to add a different noise to point positions. The run command was setting the number/name of noise channels to match the number of translate channels coming from the geo so I had enough different noise channels to add to the point positions.
Changing the number of points coming into chops wouldn't trigger the update of the amount of noise channels needed.
Just thought there might be a better way to get the channel list into the noise channels
Ill try to upload a file later if I have time
- edward
- 7743 posts
- JordanWalsh
- 143 posts
