question about addpointtogroup node in vop sop
2091 3 1- Steven Zhang
- 10 posts
I attempt to line-up point with a sequence indicated by the red line. I use a for loop in a vop sop, and I make the for loop pick points with the sequence I want. But it seems that when I add point to group it rearrange the sequence by point number which result in a the black line. How can I make it to be the red line. The file is below:
- Sadjad Rabiee
- 1391 posts
- Steven Zhang
- 10 posts
Joker386Thank you for your reply! I do hope to figure out how to work properly with vop sop, coz I don't only do this stuff. It's just a test. There're more to go afterward based on similar principle
Are you serious to solve that just inside VOP ? because you can simply solve that just with adding a Sort SOP after your VOPSOP to sort point's number By X :?
- Tesla_s_fan
- 129 posts
