Hi, sorry if this is obvious stuff (and it probably is). I've been experimenting with Houdini for a while now and I'm loving it so far, but this stuff is holding me back, so I decided to ask for some guidance.
I guess the main problem is i don't know how to correctly address and drive SOP-level Attributes (in VOPs and SOPs) for individual components in general.
For instance, I'm trying to make basic bendy limbs and i want to drive an individual Line points with SOP-level Nulls.
So Null1 drives point 0, Null2 drives point1 etc.
On one hand, in VOP SOP, I Import-Attribute a Null's position P(4f) value and i try to plug it into a Set Attribute node P(4f), but no matter how i set it up I can't get it to work.
On the other hand, forgetting VOP SOP for a while, I would like to drive a Transform Position value with a SOP-level Control's (or Null's) P(4f). How would i reference the P(4f) by expression?
If any of you could point me in the right direction I'd appreciate it.
Drive points' of a Line pos with SOP-level Nulls in VOP SOP
5663 13 2- Filip Tarczewski
- 38 posts
- Sadjad Rabiee
- 1391 posts
- Sadjad Rabiee
- 1391 posts
- Filip Tarczewski
- 38 posts
Thanks Joker386.
It works great and does solve my problem at hand, however it doesn't really answer my general question. There are two reasons:
First of all, you're taking nulls from the scene level, which i would like to avoid sometimes, so I still don't know how to address the unexposed P(4f) parameter of a SOP-level Null / Control.
Second, I would like to know how to properly get and set this data in a VOP SOP (with a SOP-level Null), since I can't see myself doing python expressions in a day to day workflow just yet (no Python knowledge or good memory for syntax and I'd prefer VOPs anyways.;-))
Thank you very much though, you got me interested in going the Python route for expressions.
If you were willing to take a peek at my scene, it's attached below.
- edward
- 7730 posts
- Filip Tarczewski
- 38 posts
- edward
- 7730 posts
- Filip Tarczewski
- 38 posts
- Platon
- 99 posts
Hi, Filip,
not an expert, but i think you're doing it wrong, “nulls” at the sop level are empty nodes, “control” node is a bunch of shape presets, but any animation, if possible, should be done at object level. You should probably at least import (object merge) nulls from object level as it will be easier to animate.
set attribute node doesn't work in “vop sop” it works in “attribute vop sop” as it is a cvex function(don't know why it is accessible in vop sop).
is this what you were trying to do?
- Filip Tarczewski
- 38 posts
Thanks owlYzarc, that's exactly what i wanted to do in this case. I knew i was doing something wrong. I'll have to look into AttribVOP, I didn't even know of its existence.
What is the difference between VOP SOP and Attrib SOP exactly though? Help descriptions don't help much:
Attrib VOP
Runs a VOP network to modify geometry attributes.
VOP SOP
Contains a VOP network that can manipulate point attributes.
Sounds to me like both should be able to move points (isn't point position a point attribute, and point a piece of geometry?). Is it that VOP SOP can't address individual components, but rather loops through all of them?
Attrib VOP
VOP SOP
- Platon
- 99 posts
well, as far as i know:
VOP SOP - is visual representation of VEX
goes through all the points simultaneously
has import attribute vop
has add attribute vop
can't create (add vertex/prim/point) or delete geometry
ATTRIB VOP (sop) - visual representation of CVEX
CVEX is newer and (I suppose) faster, but there are some differences.
goes through all the points/verts/prims/objects(detail) simultaneously
has get/set attribute
can create or delete geometry
so i guess help sort of states it with “points” vs “geometry”
- Filip Tarczewski
- 38 posts
- Platon
- 99 posts
Probably yes.
attrib vop should have (almost) everything vop sop has + more, haven't seen any chart or help page about it.
animhttp://forums.odforce.net/topic/20891-attribwrangle-vs-pointwrangle/#entry124901 [forums.odforce.net]
in general, VEX/VOP nodes based on CVEX are more generic and the trend seems to be steering away from sop/pop specific nodes like Point Wrangle/Vop Sop in favor of Attrib Wrangle/VOP, so while there are still some functions that are unique to Point Wrangle, in the future this gap should be closed and you should have all this power and much more in Attrib Wrangle (and other CVEX nodes like Geometry Wrangle DOP, POP Wrangle DOP, Volume Wrangle…) and their VOP equivalents
- Filip Tarczewski
- 38 posts
