I am building a character and would like to turn on/off certain handles based on visibility options in my asset.
When I dive into the Type Properties > Handles I see a field called “onoff” but it does not hide them, simply disables them and displays them as dashed lines.
Any idea? I don't want to see them at all.
thanks in advance
Hiding handles
2240 1 1- jordibares
- 655 posts
- Alexey Vanzhula
- 538 posts
i cant find any solution for this.
But you can temporary connect\disconnect handles via hscript.
http://www.sidefx.com/docs/houdini13.0/commands/ombind [sidefx.com] - connect
http://www.sidefx.com/docs/houdini13.0/commands/omunbind [sidefx.com] - disconnect
Add FlagChanged event to your node in OnCreate script
In event callback you can check if displayFlag is ON or OFF and respectively bind\unbind manipulator manually
Hope this helps.
Hope this helps.
