hi, is there an easy setup to trigger, by an event (like speed >0.1) a timer from 0-1 over 10frames (inside a vopsop) ??
Is this possible without a sopsolver?
thanks, tom.
Counter/Timer in VOPSOP
4194 4 2- Tom Freitag
- 84 posts
- goldleaf
- 4177 posts
- Tom Freitag
- 84 posts
hey cool…its sounds goood. i love when it appears a sopnode out of the dark and doing what you want
…BUT a vopsop solution would be nicer, because i want to drive a mix-node with two vector, which i want happens after specific condition. i.e. at frame 10 the condition happens and the a counter start from 0-1 over 5 frames. I tried with a simple fit-node somthing fit($F, triggerstart, triggerstart+blendingduration, 0,1)
the problem, which i cant solve it with SIMPLE solution, is to save a attribute (triggerstartframe) at specifiv frame “forever”.
- goldleaf
- 4177 posts
- Tom Freitag
- 84 posts
