Blend Shapes Via Spline Curve Path
   5303   3   0
I'm working off of “The Art Of Moving Points” book (excellent book btw) and it says there that blendshapes should be on a spline curve.
This makes sense because, for example, when an eye blinks, the eyelid doesn't just travel straight from open to closed, but it goes on a curve around the eye. How does one accomplish this in Houdini with Blendshapes?
If I have Blendshape SOP and I create eyelid Up and eyelid Down… it makes the eyelid travel in between the two shapes in a straight line. This doesn't make sense as the eyelid should be following the eye contour (round).
Eyes are just an example but many times you want things traveling on a curve in between blends.
I have tried wire deformers but I'm still stuck at the point of how would I make them deform on a curve (not the curve that they use, but a different curve). Is there a setting where I can use another curve as a guide? I hope I'm making sense.
Thank you
Winter is coming!
https://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=38026 [sidefx.com]
work in progress, but hope to finish this soon.
Werner Ziemerink
Head of 3D
www.luma.co.za
Werner Ziemerink
Wow - Excellent work!
You can achieve very realistic deformations. Please keep me (us) posted.
Winter is coming!
it doesn't solve the general problem, but for eyelids you might try using spherical or cylindrical coordinates.
