I'm working off of “The Art Of Moving Points” book (excellent book btw) and it says there that blendshapes should be on a spline curve.
This makes sense because, for example, when an eye blinks, the eyelid doesn't just travel straight from open to closed, but it goes on a curve around the eye. How does one accomplish this in Houdini with Blendshapes?
If I have Blendshape SOP and I create eyelid Up and eyelid Down… it makes the eyelid travel in between the two shapes in a straight line. This doesn't make sense as the eyelid should be following the eye contour (round).
Eyes are just an example but many times you want things traveling on a curve in between blends.
I have tried wire deformers but I'm still stuck at the point of how would I make them deform on a curve (not the curve that they use, but a different curve). Is there a setting where I can use another curve as a guide? I hope I'm making sense.
Thank you
Blend Shapes Via Spline Curve Path
5290 3 0-
- firefly9000
- 169 posts
- Werner Ziemerink
- 1269 posts
https://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=38026 [sidefx.com]
work in progress, but hope to finish this soon.
- firefly9000
- 169 posts
Werner Ziemerink
Wow - Excellent work!
You can achieve very realistic deformations. Please keep me (us) posted.
Winter is coming!
- Brent Watkins
- 1 posts
