Heya Folks,
I'm currently doing some RnD and I'm a bit stumped on how to make a proper normal map for an explosion. I looked up methods like RGB lights but it seems kinda complex. I included the work file that might be useful for anyone who's at a roadblock like myself S Thanks.
Division size is 0.03 so I'd increase a bit for testing purposes.
JEBUS
Rendering Normal Pass For PyroFX
6015 7 1- jebusjuice
- 19 posts
- Sadjad Rabiee
- 1391 posts
- Sadjad Rabiee
- 1391 posts
Also I suggest you to check this page too :
http://forums.odforce.net/topic/14661-normal-passes-on-volume-renders/ [forums.odforce.net]
- jebusjuice
- 19 posts
Heya Joker386,
Thanks for the workfile! I see how it's working now. I just have a quick question, is there a way to diffuse/smooth the normal pass? I tried playing with the mantra pixel samples to get a better resolution but it looks like it may be more related to a setting in the normal material? The image attached shows this issue. Thanks.
Jebus
Jebus
- jebusjuice
- 19 posts
- 8595 posts
what do you plan to use ‘normal’ pass for?
there is no proper way how you can get normals for volume
as a very rough approximation density gradient can be fine, but if you want to use it for relighting, just use per-light exports and save yourself some headaches later
- jebusjuice
- 19 posts
Heya Tamte,
Thanks for the reply. Well, the idea is to build a pipeling for Unreal. We render an explosion and export the Diffuse and Normals. The Normals has always been a tricky one to nail but in programs like 3dsmax or Maya we built an RGB light rig that's aligned to the Camera view (like a billboard). So yeah it's a total cheat, but it seemed to work. I read about something like this in Houdini a while ago but it seems incredibly complicated to setup S.
The file from Joker works really well too, and gives me some great ideas.
Jebus
Jebus
- chittewan68
