is there way i can Ctrl + C then Ctrl V copy faces (primitives Houdini calls them) from select faces pasted them into group node eg (pattern)
I am having hard time selects and then uses faces i want, because all depends node pull of shelf or your in main window or object windows
or is there way set up and Hot key so will make a group node with selected faces ? ( or mouse right mouse right click menu ) both would be great
2809 3 0-
- gfxfx
- 91 posts
- Enivob
- 2658 posts
Just make your selection and then click on the Group tool under the Model tab along the top of the interface. This will create a group node and populate the pattern field with your selection.
If you really need a copy of the original or new group you can split the network as you see fit.
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
- goldfarb
- 3465 posts
- gfxfx
- 91 posts
thank you both but after reading Enivob did bit more searching you gave me the idea see if there hot key for shelf item so searching the forum i found this work perfect
what Doudini said here see URL
but instead of “materials”
i just add “group” made hot key (you do need make a new custom shelf add the item you want to add keyboard short cut )
https://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=38238&sid=6a7e400b24cf92ac4f665dd19007084d [sidefx.com]
