Hi All,
Upgraded my AMD Phenom X6 to a FX8370 today, on an Asrock 970M Pro3 motherboard. This processor is supported by the motherboard and the Windows desktop comes up fine. I am not overclocking anything, just default CPU out of the box.
However, whenever I try to Add a Skylight to an empty default scene Houdini 15.277 crashes. Also if I add a sphere to the scene and add no lights then render with mantra, mantra crashes. This is the same exact hardware only the CPU has been swapped.
All other software, I use, seems to work fine. For instance I can render in Blender without crashes and play games without crashing and use After Effects without crashing.
It seems odd to me that Houdini would be so sensitive to a CPU swap so I thought I would just throw this out to the community and see if anyone has any tips or similar experiences?
CPU Swap Crashes Houdini 15
2397 4 0- Enivob
- 2539 posts
- malexander
- 5161 posts
- Enivob
- 2539 posts
I am using CPUID and HWMonitor to inspect my hardware. It runs as cool as the last CPU @78F idle and 142F under full 8 core load.
Blender is clearly using all 8 threads when rendering without a problem also Handbrake can encode video using all 8 threads so I am not ready to say the CPU is bad yet. It was purchased new and sealed. I have built many computers over the years so I feel like I did the install correctly with the thermal paste and fan.
Maybe the CPU needs to burn in or something funky like that..?
I managed to get some console feedback. What is odd is I see mention of VRAY in the text. I don't even have VRAY and Apprentice would not run it anyway.
This message appears in the console after I see all 8 buckets appear in the viewport.
Using Houdini Indie 20.0
nVidia 3050RTX 8BG RAM.
- malexander
- 5161 posts
- Enivob
- 2539 posts
Ah,
I did have a copy of H14.470 installed and tried that as well. Mantra does not crash, however, it does not render either. The console has a more tidy message with the TRACEBACK BEGIN/END.
Here is what is in the crash log.
Crash report from Admin; Houdini FX Version 15.0.277
Uptime 60 seconds
Thu Nov 05 14:34:11 2015
Caught signal 4
Traceback from 4900 ThreadId=0x00000758
+0x0fd30037
Uptime 60 seconds
Caught signal 4
+0x0fd30037
