Hi evryone.
I am trying to export geometrie from a hda in batch mode.
The problem is that I have a hang when maya start to open the scene.
I had the same problem few weeks ago in UI.
I fixed the problem switching off the “asynchronous Mode off”.
But in batch mode it don`t care of my preferences.
If somebody have any idea to switch off the asynchronous Mode when maya start in batch.
You are welcome.
mathieu
houdini engine in batch mode
3814 1 1-
- mathieu negrel
- 8 posts
- awong
- 818 posts
The asynchronous mode should be respected in batch mode as well. In batch mode, if you run:
optionVar -q houdiniEngineAsynchronousMode
it should show 0 for off, and 1 for on.
Maybe it's worth investigating why it's hanging in the UI? Does it hang when you clicked a button? Or is it hanging when the geometry is changing/computing?
Andrew / アンドリュー
