attributecreate and delete SOP
3255
3
1
jerry7
Feb. 21, 2016 2:37 a.m.
HI jim, You have not created Local Variable for claster attribute. You can either enable “Local Variable” option in attribcreate1 node or use @cluster in delete1 node.
Feb. 21, 2016 10:29 a.m.
Thanks. I tried checking that box before, but I think I used the default all UPPER CASE designation for the variable name. I was watching a tutorial and they didn't check that box, so it threw me off.
grayOlorin
Feb. 21, 2016 9:27 p.m.
in older tutorials, this would be the case, but it has changed in Houdini 15 (in favor of using the more direct @ syntax when possible)
-G
