I assume @ syntax is not multi-threaded regardless of looking like Wrangle VEX code?
Is one faster than the other or is it just for unification?
Is it also backwards compatible with pre-H15 releases?
pusat
Is @ syntax faster than $ in parameter fields?
1731 4 1- animatrix_
- 4523 posts
- jerry7
- 623 posts
- neil_math_comp
- 1743 posts
jerry7Could you be more specific about what you tested, in case there's an issue? I'm mildly skeptical, but there might be something unforseen at play.
I tested using Attribute Create Sop, @ is little slower than $.
Is it also backwards compatible with pre-H15 releases?The @ syntax for local variables is only in H15.
I assume @ syntax is not multi-threaded regardless of looking like Wrangle VEX code?Local variable expressions cannot be multi-threaded. There's currently a single “current point”, “current primitive”, and “current vertex” variable for SOP expression evaluation, so there can't be expression evaluations for multiple elements at the same time.
- animatrix_
- 4523 posts
Thanks guys.
That was my guess as well, it makes things nicer so I am all for using it.
ndicksonIs it also backwards compatible with pre-H15 releases?The @ syntax for local variables is only in H15.I assume @ syntax is not multi-threaded regardless of looking like Wrangle VEX code?Local variable expressions cannot be multi-threaded. There's currently a single “current point”, “current primitive”, and “current vertex” variable for SOP expression evaluation, so there can't be expression evaluations for multiple elements at the same time.
- jerry7
- 623 posts
