Polybevel Crash after 15.5.480
   4005   4   0
In the latest builds (I'm using 15.5.497 but I believe it started happening around 15.5.487) Polybevel causes an instant crash. Build 480 works fine. Anyone else having this problem?
Using Mac version.
It is better to stick with production build rather than daily build.
daily builds sometimes is considered to be unstable.
If you're in hurry, please contact with Support Team for more investigating.
Edited by Nima - June 5, 2016 19:26:35
I always keep the production build and it's solid, except for the emissions not working, which was fixed in a subsequent daily build. That's life on the edge for you
morganv123
Emission work. This is only an error within the shader. if you go inside you will see the Ce output is not connected correctly. In case u need emission in 480 you can just connect it by yourself.
I've just come across the emission bug in build 480. Can anyone explain how to reconnect it properly?
