In the latest builds (I'm using 15.5.497 but I believe it started happening around 15.5.487) Polybevel causes an instant crash. Build 480 works fine. Anyone else having this problem?
Using Mac version.
Polybevel Crash after 15.5.480
4016 4 0-
- morganv123
- 34 posts
- Nima
- 471 posts
- morganv123
- 34 posts
- Doudini
- 333 posts
morganv123
I always keep the production build and it's solid, except for the emissions not working, which was fixed in a subsequent daily build. That's life on the edge for you
Emission work. This is only an error within the shader. if you go inside you will see the Ce output is not connected correctly. In case u need emission in 480 you can just connect it by yourself.
- RickRamirez
- 36 posts
