Grabbing a domainu1 point. How?
2309 6 2- dreamagery2
- 24 posts
Would anyone know how to group the “First U” from a Carve SOP. I would like to emit particles from this slider. I hovered my mouse over this parameter, and it looks like it produces a “domainu1” attribute/variable etc.. I would love to know how you can source it in order to emit particles or do whatever.
Edited by dreamagery2 - Sept. 28, 2016 15:58:47
Greg
- A-OC
- 253 posts
- dreamagery2
- 24 posts
- A-OC
- 253 posts
- A-OC
- 253 posts
While we're here, you seem to have a fundamental misconception.
The carve sop doesn't produce a “domainu1” attribute/variable, it's just a parameter to control the Carve.
I think the “domainu1” is determining where in the implicit parametric coords to make the cut.
So if you appended the uv texure sop before the carve and display the attr in the 3d viewport, you could check it's making the cut at the uv.x = “domainu1”, I think.
- dreamagery2
- 24 posts
A-OC
Incredible. I'm actually going to try this out. You have been very helpful. I am indebted to you. Thank you.
Greg
- A-OC
- 253 posts
A-OCSo it didn't work out as precisely as I expected but I managed to adjust it. Here's the setup
The visualize node is displaying the custom u attribute.
Cheers !!
Edited by A-OC - Sept. 29, 2016 16:18:58
