pin constraint and Bullet - Stop simulation
   5503   18   1
Hi, I have so weird issue with constraints two objects and bullet solver. After 52 frames my simulation just stop. I have almost defaults settings. I have only animation (noise) in Constrained Location - Y.
Edited by Grzesiek B - Oct. 7, 2016 07:34:44
HIPsim_constrain.hip (306.5 KB)
Uuups… it's the sleeping time…
increase it or set it to 0
Edited by matthias_k - Oct. 7, 2016 11:00:58
I deleted all expressions and Still the same problem. But, when I used RBD Solver works fine - in this example. But RBD Solver some time has I problem with collisions.
Some times H. is frustrating
aha… OK …. where?
Please have a look at the image above, I've corrected my prev. post.
In the “rigidbodysolver1” Tab -> “Bullet” -> “Sleeping Time”
Edited by matthias_k - Oct. 7, 2016 11:19:19
I dont have this options. A checked all nodes inside this solver and I couldn't found
Edited by Grzesiek B - Oct. 7, 2016 11:21:32
ok…. I don't know why my bullet hasn't this option
sek, searching….
Windows -> Operator Type Manager -> Configuration Tab -> “Display Menu of All Definitions”
Then You should have the Option.
Edited by matthias_k - Oct. 7, 2016 11:34:34
Alternative do this one
hmmmm….. I don't have this option
Edited by Grzesiek B - Oct. 7, 2016 11:54:26
which version of houdini do you have?
Houdini 15.5.565
…maybe I should reinstall my H.
Edited by Grzesiek B - Oct. 7, 2016 12:00:31
Ahhh, open the “Bullet” folder…
or search in the “Filter” field below for “Sleeping”
I Have a 15.5.607
matthias_k
I did. And I don't have
Ok thax for help I reinstall and I will see.
this is a fixed version, maybe then you have the params
HIPsim_constrain-0-sleeping-time.hip (303.8 KB)
Alternative if you do not find the parameter at all…
….yes. unbelievable. really thanks for help
