Hi Guys;
In finite elements, I would like to group the fragments areas, to assign a different material.
How could I select and group them?
Thanks for helping….
My question about Finite Elements Fragments grouping ...
1466 2 0- Masoud
- 407 posts
- michiel
- 429 posts
In H16 you can modify all the material properties of your tet mesh using multiplier point attributes.
As a rule, each of these multiplier point attributes has the name of the corresponding parameter in the Model tab of the solid object. For example, you can create multiplier point attributes:
stiffness
dampingratio
massdensity
shapestiffness
volumestiffness
Inside the solver, these attributes are multiplied with the settings in the Model tab.
So if you want to make a region half as stiff as the surrounding regions, you set the “stiffness” point attribute
to 0.5 in that region and to 1.0 everywhere else.
stiffness
dampingratio
massdensity
shapestiffness
volumestiffness
- Masoud
- 407 posts
Thank you Michiel, very good tips.
I'm new to Houdini and I don't know how to use that attributes to assign several material to fractures parts
I would like to assign one material to body of my solid geometry, and another material to sliced parts…
Here in this attached image I show what I want to do :
Edited by Masoud - March 26, 2017 13:58:11
Masoud Saadatmand (MSDVFX)
