I'm trying to animate a value I have in a spare parameter to increase from 1 to 10 (from frame 1 to 120), and then back to 1 (from frame 121 to 240). However, when I keyframe the values, instead of gradually changing, it just jumps from 1 to 10 at frame 120, and then jumps back to 1 at frame 240. the spare parameter is a float one.
Thank you.
keyframing Attribute Wrangle spare parameter
2361 1 0- uuLLFA
- 90 posts
- Enivob
- 2551 posts
Sounds like your key frames got switch to some other type than linear() or bezier().
You may have untied tangents or something..?
Right-Click and delete the animated channel and re-create your keyframe animation.
Shift-Middle Click on the name of the channel to reveal the new keyframes curve editor.
Use CTRL-A to select all the keyframes and check the drop down in the lower right hand corner. It controls the function type for selected keys.
Using Houdini Indie 20.0
nVidia 3050RTX 8BG RAM.
