this might be a problem that has been solved a million times but I cannot find a solution for it.
I´ve cached out an particle animation. Now I want to duplicate this cache multiple times through a copy to point node.
Each point should be an instance of the cached animation. So far so good.
Here is the problem:
I can copy the cached animation to each copy point but the animation just continues instead of starting at animation frame 0 when copied to a point of the copy node.
Thanks in advance!
How to start a cache from beginning each time it gets called by a copynode.
947 1 0- Gabe
- Enivob
- 2551 posts
There is an animated geo example at this link [forums.odforce.net].
Edited by Enivob - April 26, 2017 13:11:50
Using Houdini Indie 20.0
nVidia 3050RTX 8BG RAM.
