Efficient Boolean of large numbers of objects
1380 2 0- RandomGex
- 29 posts
The scene I'm currently working on involves creating a structure similar to the interior of a geode. Think thousands of octahedrons densely packed onto a surface with a Copy Sop which means a lot of overlapping geometry. Does anyone have any idea on how to efficiently boolean these objects to delete out the interior geometry? Every time I try I run into memory allocation issues. I've tried both the standard Boolean SOP and converting to VDB and back to Polygons.
- 8595 posts
if Boolean SOP itself runs out of memory you can try
- iterating through your pieces within for loop to introduce one piece at a time and Boolean with previous result
- splitting your geo into few smaller clusters, Boolean those individually and then results together into final result
- RandomGex
- 29 posts
