spiral a curve around another
   9638   13   1
Any tips or examples on how to spiral one curve around another in vex? I had a crack at it but my vector math is failing me a little, and a few examples I found on this forum lacked controls for frequency offset and amplitude
You can use something like this:
https://www.dropbox.com/s/hc3ejsro1e8xwjd/Coil_SOP_Animatrix.otl?dl=1 [www.dropbox.com]
very very cool!
theres something wrong with the asset it doesnt work well…
check out the first image its created with your asset…as you can see it doesnt twist around the curve
mine works better imo…
twistAlongCurve.hip (318.1 KB)
patar
That's because you don't know how to use it.
how to make it twist along this curve as it should?
twistAlongCurveAnimatrix.hip (79.6 KB)
it seems it doesnt exactly follow the guide
yours is creating a coil alright… but doesnt exactly twist around the guide curve..
oh well use what ever you like just trying to help…not to start a war..
best regards
Patar
Don't know what your talking about - His method twists around the curves I supply for it.
And just the same as you; not wanting to start a ‘war’.
check out the image the coil doesnt exactly follow or curl around the guide curve…you can examine this especially when the amplitude is small….
who ever supply the method its not 100% correct…no need for complex math… simple high school math is enough its just sine and cosine …..
wheres my simple solution will always follow or curl around the guide curve..
The asset works perfect, my guess is you're feeding it a curve with too few CVs. Re-sample your guide curve.
ahhh yes… its working now sorry….
patar
Thanks! Most helpful.
