Cloth Mass Density Unit?
   7084   8   1
Does anyone know what units cloth mass density are in?
The tool tip claims “This is the amount of mass per volume.”
What does this mean?
How do I relate this value to the size of my piece of cloth?
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
My guess is that it's density of a matter per unit volume, which is cubic meter in Houdini:
1000cm3 of water weights exactly a ton, because density of water is…, well, 1000kg/m3
In case of cloth:
cloth_weight = area of the polygons * thickness of the cloth * material density.
Edited by symek - Oct. 12, 2017 20:54:58
Hmm..I still don't understand what the units are, even if I solve the equation.
Using the equation let's assume I have an area of 1 and a thickness of 1 and I am using the default 1,000 for my Mass Density.
How much does that weigh?
I think I still need to know what is the unit of Mass Density. If it is Kg then my 1x1 grid weight 2,200 pounds. Does that seem right?
Enivob
1000kg == 1m2*1m*1000kg/m3
Unit of mass density is not kg, but kg per volume, like unit of speed is distance per time interval.
Density unit is mass/volume, so in Houdini it is kg/m3.
Edited by symek - Oct. 13, 2017 11:06:51
additionally you can look at the units tag in the Type Properties or Edit Parameter Interface windows when you select certain parameter
Edited by tamte - Oct. 13, 2017 11:13:16
CG Supervisor
Framestore, NY
Ok, the math still does not make sense to me.
How about this…
How much does a 1x1 default grid weigh if I turn it into cloth with a density of 1000?
Enivob
With default thickness (0.001m) its wight will be 1kg.
1m2*0.001m*1000kg/m3 = 1kg
So that is 2.2 pounds.
When you write a series of symbols on the screen like 1m2 what does that mean in coding language? Is that one times the variable m to the second power?
I don't understand math symbols but I do understand code.
how do I convert “1m2*0.001m*1000kg/m3 = 1kg” to a function?
float result = 1 * m^2 * cloth_thickness * cloth_density / (m^3);
Is that right?
The series of ‘symbols’ is so that one know what the parts of the equation stand for.
So expressed in code:
float      size = 1;   // 1m2 or 1x1
float thickness = .001 // .001m
float density   = 1000 // 1000kg/m3
float result    = size * thickness * density; // result represents kg because of the units used in the formula
                                              //ie. m2, m and kg/m3
