I found docs on running PRMan engine, but it's hard on linux.
Is there any solution for it and/or for Mental Ray and not so mind blowing?
Loading PRM&MR
3829 5 1- drukpa
- 17 posts
- edward
- 7734 posts
- drukpa
- 17 posts
- edward
- 7734 posts
- drukpa
- 17 posts
- edward
- 7734 posts
Well, to get the watermark composited correctly for one, you will likely need to render from Houdini to the .picnc format and then composite your other non-Houdini rendered frames using Halo.
Then of course, there's the usual(?) slew of issues between compositing results between different renderers, and rendering scenes from different animation packages. I've never tried so I can't recommend anything.
