Apprentice won't launch and installing the latest production has the same issue:
“/opt/hfs16.5.439/bin/hkey-bin: symbol lookup error: /usr/lib/libfontconfig.so.1: undefined symbol: FT_Done_MM_Var”
Mathemaica seems to have a similar issue (https://bugs.archlinux.org/task/57948), but the applied solution there seems less than ideal for Houdini…
Manjaro Update Ruins Houdini again
4572 6 1- HongMao
- 63 posts
- malexander
- 5158 posts
- HongMao
- 63 posts
- rayfoundry
- 15 posts
- phoehsl
- 37 posts
- HongMao
- 63 posts
- jarslm
Hello, my trouble was similar like this:
# ./houdinifx-bin: /opt/hfs16.5.473/bin/../dsolib/libz.so.1: version `ZLIB_1.2.9' not found (required by /usr/lib/libpng16.so.16)
I found a similar problem with this library:
# https://aur.archlinux.org/packages/kiwix-bin/ [aur.archlinux.org]
So solution is:
# sudo ln -sf /usr/lib/libz.so.1 /opt/hfs16.5.473/dsolib/libz.so.1
Houdini works and I hope, it will be fine.
So solution is:
