Ok, this is driving me nuts. Can someone explain to me why the attached scene doesn't work?
Inside the geometry I'm defining a vector attribute and add it to P. If I do it in the same wrangle it works. Defining the attribute in another wrangle doesn't. Using a pointvop however works?
Thanks in advance!
vex: adding attributes
3093 2 1- Kaiserlicht
- 18 posts
- BabaJ
- 2042 posts
In your ‘offset1’ just before your WTF you are only using @test
which is a user-defined attribute.
You can only refer to user defined attributes as you have when it's in the same wrangle that it was first declared;
In subsequent wrangles if you want to use it you have to ‘pull it back in’ by prefacing what type it was.
so if you put it as v@test instead of @test, your WTF will go away.
v@test = set(1,2,3);
// blah blah code
// blah blah code
@test = set(2.1, 4.5, 2);// this is ok
Edited by BabaJ - Sept. 24, 2018 11:03:05
- Kaiserlicht
- 18 posts
