Fluid Sim works if I animate the emitter, but when I animate the collider, it fails.
   1971   2   2
I'm working on this fluid sim. Hey - its my second houdini project - and my first with no tutorial
Its a fluid that gets poured across a surface to illustrate a molding process.
So I have an emitter emitting fluid and a collider surface.
I originally had the emitter animating, but I think it would be better if the collider moved.
When I was animating the emitter, it worked.
When I removed the animation from the emitter and animated the collider, it stopped working.
I know its something easy (OK, I hope its something easy….), but I can't figure it out.
Thanks in advance for anyone who can point me in the right direction…..
Hexagon Fluid_10_25_18.hiplc (2.2 MB)
Hexagon Fluid_10_25_18_MovingCollider.hiplc (2.1 MB)
Just enable “Use Deforming Geometry” in the grid1 node (inside AutoDopNetwork).
Thanks. I’ll try that Monday.
