Is there a way to convert the UV Layout into geometry on the XY plane?
I have a 3d object, and I use UV Layout to generate a nicely packed set of polygons in UV space. Now I want to convert those geometries into polygons on the XY plane.
Convert UV Layout to geometry on XY plane
2146 3 2- phtj
- 224 posts
- Midphase
- 833 posts
Maybe this might help?
http://www.entagma.com/houdini-17-quicktip-packing-geometry-using-the-uv-layout-sop/ [www.entagma.com]
>>Kays
- Konstantin Magnus
- 670 posts
In a point wrangle assuming the UVs are stored on vertices:
To keep the UV islands separate use the vertexsplit node first and set its attribute parameter to uv.
v@P = vertex(0, 'uv', @vtxnum);
Edited by Konstantin Magnus - Oct. 31, 2018 03:35:20
- phtj
- 224 posts
