Operator Path Parameter in Multi-Parameter block Doesn't work properly
   5796   5   0
I am trying to add OperatorPath parameter in Multiparam block for processing multiple geometry but in Max whenever I am trying to add new param, it removes all the geometry added before it and have to again add other geometry in one go. Also Name of geometry also doesn't appear.
Thanks,
multiparam_operatornode.hda (6.0 KB)
Are you seeing this in Houdini 17.0.352?
BrandonA
Yes. I have attached the HDA m using inside 3dsMax.
Let me know if you need more info
Thanks,
Is this a known bug or m doing something wrong?
Thanks,
The names of the objects not showing up in multi-parms is a known issue.
I'm not able to reproduce the problem with the geometry being removed. Do you have steps for reproducing this?
BrandonA
Sorry I am not able to reproduce it. Maybe I clicked something wrong. Again Sorry.
Thanks,
