Dear All,
I'm just wondering whether there is a way to know which primitives have been (manually) selected by the user, but through the Python API. I know you can have that information for the selected nodes through the hou.selectedNodes() or do some node selection with Node.setSelected(), but I've found no equivalent to know/set the selected primitives… is there a way to do it?
Thanks!!!
dagush.-
Selected prims in Python...
9068 7 2- dagush
- 98 posts
- graham
- 1908 posts
In order to do anything regarding selected stuff in the viewport you'll need an instance of hou.SceneViewer. To select prims, or get any currently selected ones you would then call selectGeometry() and get the selection string from the resultant hou.GeometrySelection object.
There is no way to use Python to select any geometry entity in the viewport however.
import toolutils
viewer = toolutils.sceneViewer()
geo = viewer.selectGeometry()
print geo.mergedSelectionString()
import toolutils
- zarti
- 330 posts
graham
might be interesting , if that wd be true someday .
first thing that comes in my mind ; different selection patterns ( 1 of nth , next loop , previous loop , etc .. )
… oc , ideally assignable to shortcuts for viewport modelling sessions .
.cheers
- dagush
- 98 posts
Thanks!!!
Now, with the risk of asking a really silly question, where can I find informatio on the toolutils library? I've seen it several times mentioned at the forums but I've never found any documentation about it…
Thanks again!!!
dagush.-
Thanks again!!!
dagush.-
* skylineEngine project coordinator
* buildingEngine module developer
http//ggg.udg.edu/skylineEngine
- graham
- 1908 posts
toolutils is a Python module shipped with Houdini. It is located in $HFS/houdini/python2.Xlibs/. It, along with most of the other Python modules Houdini uses, are located in there. They contain some documentation in the form of docstrings and code comments.
- dagush
- 98 posts
- Andr
- 900 posts
graham
import toolutils
thanks!
With primitives already selected in the viewport, I call this code from a button parameter: it returns the values, but also the viewport will lose the selection. Do you know how to avoid that?
It seems that it is the hou.SceneViewer.selectGeometry() function to cause this behavior.
I'm reading [www.sidefx.com] that the function should expect the user to perform the selection first and it would return the selected prims.
ps. I'm also getting this error sometimes: Execute Code - Recursion in parm callback
Edited by Andr - Feb. 3, 2019 04:45:33
- Andr
- 900 posts
