I have to bump this thread because it's happening to me too. I tried different graphic drivers but it stays the same. Curiously, it started happening all of a sudden. it was working fine and then it didn't anymore.
Also, it is telling me: “Error: Outdated OptiX version (expected 5.1.1, found 5.1.0). Please re-download OptiX Denoiser.”, which I did, but it keeps giving me this message. I tried manual download and adding the path to the ENV file, but nothing changes.
OptiX is still working when I select it on the Pixel Filter and render to disk.
The only thing I have left is going back to previous Houdini build… but what's the point of that.
Right now I'm in 17.0.459 with a GeForce GTX 1080 ti driver 417.71 (tried 4 previous releases).
While I was in Houdini build 17.0.416, it was working fine.
I have uninstalled Houdini (17.0.459), including the folder it creates in Documents, reinstalled (same version) and then “re” downloaded OptiX from the Render menu.
This solved the problem for me… hopefully it doesn't happen again.
Houdini 17.0.459 appears to be working with OptiX 5.1.0 instead of 5.1.1, even though the render view shows an error (“Outdated OptiX version (expected 5.1.1, found 5.1.0). Please re-download OptiX Denoiser.”). I don't know if it's the Touring architecture or something else, because it happened to me right after I added a RTX card in my PC.
hi2alexmunteanu Houdini 17.0.459 appears to be working with OptiX 5.1.0 instead of 5.1.1, even though the render view shows an error (“Outdated OptiX version (expected 5.1.1, found 5.1.0). Please re-download OptiX Denoiser.”). I don't know if it's the Touring architecture or something else, because it happened to me right after I added a RTX card in my PC.
Optix 5.1.1 is incompatible with Turing/RTX cards, so it was rolled back to 5.1 since 17.0.464. If you install this (or later) build, you won't see the “outdated version” warning anymore, and the “Download OptiX Denoiser” in the Render menu will link to 5.1.
I had installed a trial of Redshift and this caused the problem. Might have been something to do with the environment variables I had to add. As soon as I commented them out again the orange renders using OptiX went back to proper renders.
