I just installed the new version of apprentice on my laptop and when i go to start it up i get this error.
3400: Fatal error: Segmentation Fault
Saving application data to CDOCUME~1/Adam/LOCALS~1/Temp/Adam.3400.hip
i'm assuming its not being able to start the save file for some reason, but would like a bit more information if possible please. I'm running XP pro, and the license installed fine, when it boots the main window shows up, but the 3D viewpanel stays showing my desktop, then the message of that fault shows up in the message window. i have to open task manager to make them go away.
my laptop isn't a graphics machine, but i believe it meets the minimum requirements…
i have no problems with the version on my desktop, but the one i downloaded today for my laptop developed this problem.
thanks.
Houdini apprentice crashes on boot
5510 9 0- Tzalaran
- 11 posts
- edward
- 7743 posts
- Tzalaran
- 11 posts
License Administrator opens fine. no problems with it opening.
Radeon IGP 320M is the graphics adapter my laptop has, and my driver is 6.14.10.6368 from ATI.
neither houdini master or select will open, i didn't test any of the others, but i tried those two, and i downloaded Houdini 8.1.648
and thank you for the assistance. 8)
“For can not the mind create a heaven of hell, and a hell of heaven.” Milton
- edward
- 7743 posts
- Tzalaran
- 11 posts
- edward
- 7743 posts
- Tzalaran
- 11 posts
- Tzalaran
- 11 posts
- edward
- 7743 posts
- Tzalaran
- 11 posts
i don't do most of my work on my laptop, so i'm not that concerned with performace on it… anything graphics oriented doesn't run well on it.
i just wanted to be able to model anywhere when i got inspired. i'm rarely at home, so now i might have more opprotunity to learn and create with houdini.
Thanks again for the direction. 8)
