Is there anyway to grouping or select fur guides?
I was struggling with making long hair in houdini.
I'd like to select some specific guides and groom it using grooming tool(screen brush) like other fur tools.
Any good solution or tip for grooming long and complex hair?
Grooming hair guide? select guides?
6314 5 0- SooHee Kwak
- robsdesign
- 236 posts
Hi, I can't answer you question in particular (someone else probably can) but I did find this great video regarding hair made by Andrew Brown.
https://vimeo.com/88711732 [vimeo.com]
I found the Blender technique works well for guide hairs. (around 41min into video) Personally, I feel that I have better control of the guide hairs using Blender compared to Houdini. (especially for long hair)
hope that helps
Rob
hope that helps
Rob
- YasinH
- 55 posts
- anon_user_89151269
- 1755 posts
- YasinH
- 55 posts
- abvfx
- 71 posts
Btw it isnt possible to hotkey this button without the use of a script.
Hotkey this script and you should be able to invoke it without having to keep clicking that button.
Thanks for the shoutout but anyone looking at that video should check out the H16 and H16.5 fur masterclass videos. As the old houdini fur techniques are obsolete imo. New stuff is amazing.
import toolutils
import furtoolutils
node = hou.selectedNodes()
sv = toolutils.sceneViewer()
selection = sv.selectGeometry(“Select Curves To Groom”, 0, True, False, False)
kwargs = node
furtoolutils.startGrooming(kwargs, tool=“groomscreen”)
if(len(selection.selectionStrings())) :
node.parm(“group”).set(selection.selectionStrings())
node.parm('stroke_changedsel').set(True)
Edited by abvfx - June 8, 2019 11:53:51
Senior Groom TD @ Industrial Light & Magic - abvfx [abvfx.me]
