I tried to use the opadd command but it doesn't know any operators.
When I use the helpfile example (“opadd geo arms legs”) it gives me this:
“Unable to create node type geo”
if I type opadd it gives me no operator list as it should
is this functionality locked in the apprentice?
martin
hscript in apprenctice
9105 8 2-
- sanostol
- 621 posts
- edward
- 8154 posts
- RickW
- 141 posts
- sanostol
- 621 posts
- VisualCortexLab
- 509 posts
I second Rick on this… i did a python script which add few Sop and Vops… and i had many “opcd” to get this done… which is quiet useless if you can opadd from the “root”…
JcN
VisualCortexLab Ltd :: www.visualcortexlab.com
- rvinluan
- 1473 posts
- RickW
- 141 posts
- Le_monkey_butt
- 166 posts
- thomas.waldinger
- 10 posts
in the meantime you could use a script like this.
it's written on the fly, so excuse me if it's not that elegant.
# opaddglobal.cmd
if ($argc > 2) then
shift
set newDir = $arg0
set dirExist = `opexist($newDir)`
if ($dirExist == 1) then
shift
set oldDir = `run(“pwd”)`
cd $newDir
set op = $arg0
shift
while ($arg0 != “”)
opadd $op $arg0
shift
end
cd $oldDir
else echo Dir does not exist
endif
else
echo usage oppaddglobal.cmd
endif
# opaddglobal.cmd
if ($argc > 2) then
shift
set newDir = $arg0
shift
cd $newDir
set op = $arg0
shift
while ($arg0 != “”)
opadd $op $arg0
shift
end
cd $oldDir
endif
else
endif
ops:
