Attribute on the output not working
   2235   1   0
I am using an opengl node to create my previews just just after a generic work item node with a couple of work items with the image output being like:
$JOB/Houdini/flip/$OS_`@pdg_index`/$OS.$F4.jpg
And it is not working the attribute doesn't expand, any tips?
Thanks.
Try using $JOB/Houdini/flip/$OS.`@pdg_index`/$OS.$F4.jpg instead - note that the $OS_ has become $OS.
The problem is that _ is a valid environment variable name token, so the expression continues to try to parse your string as an env var. That's why all of the default paths with $varaibles in ROPs/TOPs are separated with dots instead of undscores.
If that doesn't work, please attach a .hip.
